VGTA performance test is design for verify VGTA characters in all processing.
Programming by LabVIEW, easy to maintenance, modify,and improvement.
set different case to get different performance, for example, the 100 10% to 140 is no overshoot, and to 145 over has overshoot.
The hardware use CAN bus, power supplier, sen CAN message and get responce signal.
