See "screenshoot.png" to have a look of the block diagram!!![]()
This is an example of Scaled Invariant Geometric Matching.
It has been developed using LabVIEW 2013 and IMAQ functions.
Inside the zip file you can find the code and test it using images inside "images" folder.
"Gauges 00.tif" and "Gauges 10.tif" differentiate each other only by the object in the left down corner; the one in the "Gauges 10.tif" is o
btained by the one in "Gauges 00.tif" through a 112% scale procedure.
Inside the code you can select the scale factor upon which to base the geometric matching research, as indicated in the free label posted in the block diagram.
