Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
Overview
Example on how to use shared memory to share data between labview vi's and other applications. Incudes an example that shares data between two vi's. Compiled for 32 bit. Source included so dll can be modified and recompiled for 32 or 64bit. Used the Labivew .dll import wizard to automatically create vi's if you recompile the dll. (Select the LabviewSharedMemory.h as the header file.) Currently aloows the writing/reading of a 100 element float array.
Description
Example for using shared memory (windows only) in labview.
Run the Write and Read Example VI's
Requirements
Software
Labview 32 bit 2014
Additional Images or Video
Provided
I noticed that the Call Library Function has the option "Thead" in the Function-tab configured as "Run in UI thread". I'm using this library in a time critical part of the code and I want to avoid issues caused by the Root Loop (More info: https://www.winemantech.com/blog/the-ui-thread-root-loop-and-labview-what-you-need-to-know/ or http://www.labviewcraftsmen.com/blog/the-root-loop)
Is this DLL thread safe and therefor possible to configure the Call Library Function to use the option "Run in any thread" ?
How to recompile the code to 64 bit?.
I tried recompiling it in Visual Studios 15. But,it throws an error (fatal error LNK1112: module machine type 'X86' conflicts with target machine type 'x64').
Thanks in advance!.
