Community Documents
LabView 2010 - Timeout error
I have a program which have to communicate via Mobdus with ratemeters (Bronkhorst EL-Flow). The program worked until today, but now an error occured and I don't know how to remove it. The errors status is : "Timeout error".
I have seven ratemeters connected on a bus, their adress go from 1 to 8, according to the datasheet of the ratemeter, they are programed as 19200 bauds.
Thank you for your help.
I have join the vi.
Peter.
Labview 2010
Comments
Pete.Dunc
Active Participant
Active Participant
on
Hi Peter,
This question would be better suited and have a much larger audience in the forums. There are several dependancies (SubVIs) which are not included in your attachments meaning we cannot see how the VI is operating - if this is built as part of a project I would recommend creating a zipped folder build.  Attach this to your forum post and we will help you out
A few quick things to check:
  • Are all the devices powered?
  • Have you changed development machine?
  • Has anything changed from when this was running correctly?
Please post the link to your forum post in the comments here.
Peter D
Peter Saraiva
Member
Member
on
Ok I will post it in the forum with the subVis,  I forgot it
Yes all the devices are powered. People who used this program before used it on the same computer.
I don't know if anything was changed because I didn't do this program so I don't know how it works exactly but I still try to understand.
Meet me on the furum
Thank you for your response
Peter.
Labview 2010
Peter Saraiva
Member
Member
on
I opened a new topic in the forum and it have all the VIs
Peter.
Labview 2010
Pete.Dunc
Active Participant
Active Participant
on
Link to Forum Post
Peter D
Contributors
