Contact: | Ted Delaplaine |
Meeting Details: | Quarterly meetings, 11:30 a.m. – 1:00 p.m. |
User Group Website: | http://decibel.ni.com/content/groups/nicommidatlantic |
We have several rotating test stands we control using LabVIEW code. The main user interface is a desktop PC with touch screen, flat panel LCD screens. This was for ease of operator use and to add a bit of a high tech factor.
While this works great for simple button pushes, I want to provide some dialog boxes that the operator could use to punch in parameters such as speed and torque in a calculator keypad type of interface with buttons large enough that they can use the touch screen. Also, I wanted to provide the means that they could continually nudge up and down whatever was the current value of the control. With these dialogs, the operator should rarely need to touch the keyboard or mouse.
Other factors of concern:
To provide a dialog box that is linked to a front panel control so that an operator can enter numeric values using a touch screen LCD monitor. Also provide an alternative dialog box where that remains on screen as long as needed so they can make incremental changes to the linked front panel control.
Main Front Panel:
Number Pad Front Panel:
Up/Down Front Panel:
Main Block Diagram:
Number Pad Block Diagram:
Up/Down Block Diagram:
Nice code! Did you run into an instance when you needed this functionality and that's why you coded it up or was it more of a brainstorm then necessity?
Thanks Grant.
I basically did need this functionality. It wasn't absolutely necessary to have it, but it by creating it, it gave an extra WOW factor to my applications.
Our company had just invested a lot of money in a new R&D facility that included upgrades to our current machines as well as some new test machines. One of the mandates was to make it a show piece, something that when we showed it to visiting customers they would be impressed. We invested in NI hardware such as the compact Fieldpoint for the control systems and I wrote the code myself. The operator interfaces running on PC 's have front panel displays with images of the particular test stand they are controlling with status indicators matched up to pieces of the machine. Basic Start/Stop/Direction and other On/Off control buttons populate the screen.
I figured what cooler way would there be to start a machine other than touching the button on screen and having it react. So I invested in some relatively inexpensive flat panel LCD screens that also had touchscreen capability.
Then I said, wouldn't it be nice if we could basically hide the mouse and keyboard in a drawer and only use them if absolutely needed. But some of the controls required a typed in input such as the speed or torque setting. How do I do that with a finger that is acting like a mouse. So I created the number pad dialog that looks like a calculator with big enough buttons for a person to touch. Since I needed to do this with more than one numeric input, and each numeric control has its own range limits, I used the techniques in the main VI using control references to determine which control the numberpad dialog acts on.
The number up/down dialog grew from that because sometimes we don't want to enter a specific speed, but want to be able to manually ramp up or down a speed at our own pace. So I created the up/down dialog that remains on screen so that the operator can change the value at their own pace and not have to continually key in a new value.
With these two dialogs, I've used them across 3 different test stands and the operator doesn't need to touch the keyboard.
-Bill
Hi RavensFan,
Thanks for the great code. Could you please share about the Hardware used and its Connections?
Thanks a lot in advance
We used compact Fieldpoint to read analog sensors and digital inputs, and output to analog outputs and digital outputs for relays. The machines were driven by electric motors with variable frequency drives. The newer versions of those drives can be communicated with using Modbus RTU over RS-485, but I had one older drive that I had to create a driver to match their ASCII protocol and used that over an RS-485 serial line.
