Install guide for Raspberry Pi 2/3, LabVIEW2014 Home Bundle, and associated software. The steps covered in the guide are:
From the intro:
This install guide outlines a step-by-step process for installing LabVIEW 2014 Home Bundle and the LabVIEW MakerHub LINX package for use with the Raspberry Pi (RPi). The flow has been tested on an RPi 3 Model B, but it should also work for an RPi 2 Model B; note that these are the only two RPi models which are supported by the MakerHub package. The following points are also important to note in using this guide:
Note if you have any issues during the installation procedure, the MakerHub forums will likely be a better place to get answers. I'm only good for when things go right!
When I try to expand the partition, the whole install just hangs. I think this is due to NOOBS making a zillion partitions and confusing the installer.
I was able to get it up and running by ignoring that option and just installing it. However, the installer then hangs at reboot. I've heard that the Pi actually does reboot, but I use Tera Term to log in and reboot it manually anyway.
I'm curious to know exactly what was wrong with my setup, because it would seem that the people with both a NOOBS installation and issues like mine are in the minority.
I was going to point you to the MakerHub forums, but I see you've already posted about this problem over there. I'm something of a Linux beginner, so I don't know how to help with the partition issue. For the record, I carried out the installation procedure on two NOOBs RPi's, and didn't have any issues. But that part of the installation (Section 9 in the document) is the one area where problems are most likely to occur, because the LINX-install wizard could do with some improvement (imo). A step-by-step wizard would be better, with more feedback to the user about what is happening at any given point. For example, it often appears like the installation has stalled, but that might just be because some steps seem to take a really long time.
Sorry I don't have more to offer on the problem you saw, though.
Not a problem at all. It's probably some combination of things that will make it really difficult to troubleshoot. ![]()
Thanks for responding so quickly.
Bill
Hi all,
How can I run appliation on raspberry with interface from LabVIEW?
Boone
