Overview Lat/Long position to UTM coordinates
Description Converts a position expressed in Lat/Long degrees, as from a GPS device, to rectangular coordinates in the UTM grid.
Requirements
Software labview
Hardware Windows PC
Additional Images or Video
This VI has a problem with the zone calculation, at least for my location (Longitude 147E, zone 55).
I got a better result using: RoundDown((Longitude + 180.0)/6.0)+1
Also this VI leaves out a final scaling. If a negative Northing is calculated, it should output (Northing+ 10,000,000.0)
(as per referenced javascript implementation).
