Contestant Info:
Milwaukee, WI
Wisconsin Milwaukee Area Group. Not listed in all groups, we are coordinated by Chris Nelson and have had only one meeting.
This Labview scripting tool takes a standard VI, and creates a wrapper around it to launch it as a daemon. This is useful for creating inline code modules that need a process to run in the background. Accessible through the tools menu option.
Accessing the tool:
Main Block Diagram:
Run Target VI Case:
In later rounds I'll replace the scripted tool with a block diagram node which will run any static VI reference as a daemon. It will be identical to programming a call by reference node, but it will not wait for the VI to finish...
note: This code was originally submit to the www.lavag.org code repository on 2-25-2011. I consulted the NI rep governing the rules of this contest and this code has met the submission criteria.
Good code! Could you add some documentation to your block diagrams so it's easier on other programmers to quickly look and read what is going on and why. Thanks!
Hi! May I ask where the property nodes regarding the connector pane come from?
Nice functionality by the way!
Property nodes regarding connector pane?
The connector pane of the daemon launcher is set from the connector pane of the source VI, it is scripted.
Open the .lvproj file in the zip and look at the test create.vi (or simmilar, i forget what i called it.) Follow the comments in the code and things should be a little more clear.
These are scripting property/invoke nodes. You must have scripting enabled in your labview environment to see them.
Here are the steps (https://www.ni.com/docs/en-US/bundle/labview/page/enabling-vi-scripting.html) to turn on VI Scripting in LabVIEW 2010. VI Scripting has been an internal tool for many years but with LabVIEW 2009 we made it available as a ni.com/labs download. Starting with LabVIEW 2010, VI Scripting is now shipping with LabVIEW but since it is an advanced topic you add the extra step to turn it on.
Thanks, that was the exact piece of code I looked at. In my LV2010 scripting was enabled, but I currently opened your project in 2009. I thought that scripting nodes are blue, as they really are, but these nodes showed up for me as yellow. That's why I did not understand where could you select such elements in prop in invoke nodes. After installing scripting in 2009, now I see them as blue, and of course they are selectable for me too.
Thanks again!
For anyone looking for VI Scripting in LabVIEW 8.6 or 2009, here (https://www.ni.com/en/support/downloads/tools-network/download.labview-vi-scripting.html) is the ni.com/labs link for the download. You should be able to download this and then have access to the VI Scripting nodes.
