Community Documents
Convert Decimal to Zero-Padded String
Overview
LabVIEW contains many functions for converting a numeric input to a string.  In certain cases, however, we would like to specify the number of digits by which the output string is represented.  This VI demonstrates how to convert a numeric to a string, and pad it with zeros until the desired number of digits is reached.
Description
This code takes a numeric input, and outputs it in string representation with the number of digits specified by the user.
  1. Specify the Numeric Input to be converted.
  2. Specify the Number of Digits.
  3. Run the VI
  4. View the Output String
Requirements
Software: LabVIEW 2012 or later
Hardware: none
Andy G
Applications Engineering
Comments
ttxtry
Member
Member
on
Contributors
