Attached is the code presented at the May 21st meeting. The simulated temperature logging program uses a Queued Message Handler and simulated DAQ device. Follow the instructions to create a simulated DAQ device and install the OpenG Variant Configuration File Library. The code will be broke if you do not install the OpenG Variant Configuration File Library.
Use VI Package Manager and download OpenG Variant Configuration File Package. Install the OpenG Variant Configuration File Library.
Matt
Matt Fitzsimons
NI Alliance Member
LabVIEW Champion
NI Certified LabVIEW Architect
LabVIEW, LV-RT, Vision, DAQ, Motion, and FPGA
