CMC Driver Framework
Error 63 when running Driver Framework Code
If you receive Error 63 when running your driver framework code, this is likely due to a VI Server communication error. The Driver Framework uses VI Server to communicate with a global Console dialog, enabling one dialog to be used across projects.
To resolve this issue:
  1. In LabVIEW go to the Tools menu and select Options
  2. Select VI Server
  3. Ensure that TCP/IP is checked, Port is set to 3363, and the Machine Access List includes the IP address of your PC. If it already includes " * ", that will also enable VI Server for your PC (as well as all others who attempt to communicate with it).
  4. Restart LabVIEW
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 1 of 1
(2,636 Views)
