Biomedical User Group Discussions
low cost Image frame grabbers with LABVIEW
I am looking for low cost image frame grabbers for use with labview. Please suggest some as I intend to use them in motion analysis application.
Look forward to hear from you all
Regards
Amanmeet Garg
(8,251 Views)
Probably the lowest cost approach is to skip the frame grabber and go with a FireWire or GigE camera (or even USB if performance is good enough).  Here's a good article to help choose the right bus: http://zone.ni.com/devzone/cda/tut/p/id/5386
(4,246 Views)
Dear Amanmeet,
Another alternative is using a CompactRIO with an analog frame grabber such as the AF-1501 (US $495).
http://www.movimed.com/AF1501-framegrabber.htm
This frame grabber is compatible with all NI Vision VIs.
Here is a getting started tutorial for the frame grabber: http://www.movimed.com/af1501-frame-grabber-quick-start-tutorial.htm
Best,
Markus Tarin
(4,246 Views)
