Biomedical User Group Discussions
can anyone please tell me how to recover a signal from excel sheet
hi
i have an excel sheet consisting of signal amplitudes as shown in below example with respect to their time,please tell me how to construct a signal from them.i am attaching my saved signal excel file
eg:        time    amplitude
              712    0.0424805
              713    0.0297852
                to       to
             1800  0.000283
(5,127 Views)
Hi illa,
It is not that difficult. In LabVIEW, you could use read from spreadsheet. (Save the xls as csv).
Thanks!
ZJ Gu
(3,927 Views)
i am able to display the graph  i converted my Excel sheet to tabdeliminated format and displayed the graph
but i am unable to get the FFT of that please see the attachement i have attached my sanpshot of VI.
please tell me how to convert cluster of two elements to waveform
(3,928 Views)
Accepted by topic author Illa
A waveform is essentially a cluster of three elements - a timestamp, t0, the time interval between the data points, dt, and the data Y.  To create one with your data, drop a Build Waveform primitive from the Analog Waveform palette.  Wire your Y data to the Y input and the difference between your first two X data points to dt.  You can leave t0 at the default (0 = 12PM Jan 1, 1904) or set it to something real.
(3,928 Views)
sir i did it but when i am caluclating FFT for that stored data but why X axis time instaed of frequency. i am attaching my waveform and data please have a look
(3,928 Views)
You set the dt =1. that means your sampling rate is 1Hz. I don't think it is right. Please set it to right value. And please use Signal Processing  -> Waveform Measure -> FFT Power Spectrum and PSD.vi to calculate the spectrum. I think you are using pure FFT VI. It will not include time/frequency info. Just do a pure "FFT" math calculation.
Thanks!
ZJ Gu
(3,928 Views)
