Biomedical User Group Discussions
Fix ActiveX graph
I have a problem, anybody can help me?
I can use all 3D graph but ActiveX 3D Curve, ActiveX 3D Parametric Surface and Active 3D Surface. anyone can tell how to fix the problem and where can I download the software?
(4,597 Views)
Could you please tell more about your system/software like which OS, whicy LabVIEW version you are using? And it may get answer more quickly if you post this question in other LabVIEW group as this is more regarding to Biomedical applications
Thanks!
ZJ Gu
(3,628 Views)
ZJ
I have two computers and one is vista with labview 2009, another is window 7 with labview 2011. I try to look for the cause on the web, maybe need I to install VC++ on my computers?
Guangjun
(3,628 Views)
No, I don't think so. Maybe you could directly call your local NI support number. It should be a general issue.
Thanks!
ZJ Gu
(3,628 Views)
ZJ
Thanks,I will try to do it.
Guangjun
(3,628 Views)
