Biomedical User Group Discussions
EMG Filtering
Hai.
I am new to labview and currently i am working a project related to EMG. My idea is to filtered the signal that have been read from the datasheet and plot the signal to graph.
My problem is to determine the types of filter and its cut off frequency.
Can someone help me.
Thank you
(4,238 Views)
Saidatul,
There are filtering design examples in the NI Example Finder. In the LabVIEW development environment, select the menu item Help:Find Examples...Search on the keyword "filtering" and you'll be presented with a list of example VIs -- any greyed out examples require a toolkit/addon that's not present on your development PC (see attached capture). Good Luck.
-Iggy
Iggy Calalang
CTA Badge CPI Badge CLD Badge
(3,876 Views)
