Biomedical User Group Discussions
Algorithm to Discriminate Noise Term and Select a Channel Automatically
Hello.
I have some questions.
I have created a system that evaluate R-R interval, and Heart Rate Variability automatically with non-contact heart-rate signal measurement system.
However I have two problems.
I can't discriminate noise term from normal term contained in heart-rate signal automatically.
the noise term and normal term are defined as blow.
normal term
 the waveform is periodic, have recogizable pattern.
noise term
  the waveform is non-periodic, and the amplitude is too big.
For exemple in this case,figure 1, there is noise term clearly.
In noise term, the waveform seems random.
    figure1
the system output 4 types of heart-rate signal.Thus I get 4 signal channels.
Then I have to select the well suited channel which the waveform is periodic, and there isn't noise term automatically.
For example in this case, figure 2, I should select channel2.
Because the waveform have very recogizable pattern and very clear peak .
However I have no idea that select the channel automatically.
    figure2
If  you know sollution method,please advise me.
Thank you
yosukeT
Message 1 of 1
(3,157 Views)
