File Format Converter
In the biomedical signal processing field, software and hardware equipment generate different types of data files. The File Format Converter is a LabVIEW application that converts files of different file types for use in various applications.
This application includes the following features:
Complete the following steps to load data of one file type and convert specific signals from that data to another file type.
1. Launch the File Format Converter.
2. In the Operation section, click the Browse button next to the Input path text box and navigate to the data file you want to load.
3. Click the OK button.
Note The Output Path automatically populates with the same folder path as the Input Path. You can click the Browse button next to the Output Path text box to select a different location to save the converted file. |
4. Select the file format to convert the exported channels to from the Output Format pull-down menu.
5. In the Channel Settings section, select the channel in the Input column that you want to convert and click the add button. This channel appears in the Output column.
Tip Click the Add ALL button to select all the channels in the data file to convert. |
6.Click the Start button to convert the channels in the Output column. A dialog box displays with the location of the new data file.
