Hi All,
For some of you may want to load large image data using biomedical toolkit. We built a 64bit version LVDICOM.dll with which you can use Image File IO VIs in 64bit version LabVIEW 2013.
Step 1. Install 32bit and 64bit versions of LabVIEW 2013
Step 2. Install Biomedical Toolkit 2013
Step 3. Copy the Biomedical folder under "C:\Program Files (x86)\National Instruments\LabVIEW 2013\vi.lib\addons" to "C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\addons". (Notice that the first and second grey folder path are the installing path for 32bit and 64bit labVIEW respectively).
Step 4. Download LVDICOM.dll in the attarchment and copy it to "C:\Program Files\National Instruments\LabVIEW 2013\vi.lib\resource".
Step 5. Copy "C:\Program Files (x86)\National Instruments\LabVIEW 2013\menus\Categories\Biomedical" to "C:\Program Files\National Instruments\LabVIEW 2013\menus\Categories\Biomedical" and C:\Program Files (x86)\National Instruments\LabVIEW 2013\menus\Controls\Biomedical" to "C:\Program Files\National Instruments\LabVIEW 2013\menus\Controls\Biomedical" if you want to see Biomedical Categories in Palettes and Controls.
Hi All,
Since we have received many requests on using 64bit image File IO VIs, we posted a initial test version dll here for all users with interest to have a try. Sorry that we don't assure of full quality, we need your input for improving the quality ![]()
ZJ Gu
