BLT for LabVIEW (Build, License, Track)
How to disable Licensing checks for my application
When you distribute your LabVIEW application with BLT, you can avoid having your application to do licenising checks.
If you do so, your application will still continue to receive automatic updates and report errors and logging information.
Follow these steps in order to disable License checks:
These steps must be completed after you've configured the BLT Build Specifications for your application!
  1. Open the LabVIEW Project of your application and locate the STARTUP_VI generated by BLT.
  2. Open the STARTUP_VI and display its Block Diagram.
  3. Set the "Enable Licensing authentication" boolean constant to FALSE
  4. Save your VI and rebuild your application with BLT.
Matthias Baudot | Software Architect | Founder & Owner at STUDIO BODs | DQMH® Consortium Board Member & Trusted Advisor
STUDIO BODs     LabVIEW Champion     Certified Professional Instructor     DQMH Trusted Advisor     DQMH Consortium Board Member     GCentral Sponsor
 Check out my LabVIEW presentations and videos!
Message 1 of 1
(5,555 Views)
