Automotive and Embedded Networks
trouble with nican.dll
I'm trying a communication CRIO with a driver by CAN, but the download of host VI to CRIO fail:
 - Failed to download ncOpen.vi
-LabView:Failed to load shared library nican.dll
ncOpenObject:E on RT target device
I ready update nican.dll with 2.4 version
regards
RC
Message 1 of 8
(8,687 Views)
Hi
Make sure you have installed ni-rio 2.1 Here is the Link . Or ni-985x 1.2.1. NI-CAN supports only cRIO 900x controllers running Pharlap RT. There is no support for cRIO 90xx Controllers running Vx Works. The use of NI-CAN api functions makes only sense if you try to use the virtual interface for frame to channel conversion. Otherwise you have to use the FPGA elemental I/O to access the 985x  c-series modules. The cRIO drivers mentioned above install examples for these cases. The LabVIEW help describes the "How to".
DirkW
Message 2 of 8
(8,669 Views)
Do you know of anyone that has developed API's for use on the RIO 9012 or whether NI are releasing an API any time soon?
Message 3 of 8
(8,121 Views)
Hello Yougo,
Unfortunately you need to develop you own API on your controllers based on VX Works.
Manuel R
AE dans une autre vie
Message 4 of 8
(8,099 Views)
Right now there is no NI-CAN support for VxWorks available, but we are looking into this right now, because of the increasing number of Requests, like yours. But i can not tell any timeline or release date yet. Hopefully this works out until the  end of the year.
DirkW
Message 5 of 8
(8,093 Views)
Well.... it is now September, 2011.
Are the NI CAN drivers available for VxWorks?
Message 6 of 8
(5,922 Views)
Howdy,
Still no support for NI-CAN in VxWorks, but there is NI-XNET support for the NI-9862. If you are using the NI-9853 it might be possible to use the NI-XNET Frame to Channel Conversion library to bring data from the FPGA and use NI-XNET VI/databases to work with the Frame and Signal information.
Joshua B.
Message 7 of 8
(5,917 Views)
Hi triviper,
Indeed, the NI-CAN driver/hardware is slowly being replaced by NI-XNET because this latter is better suited for other protocols such as LIN or FlexRay. Which explains why there won't be a driver directly used by cRIO under VxWorks. As stated several times, there are libraries to use to import CAN data from the FPGA to the RT part.
Rik.
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
Message 8 of 8
(5,906 Views)
