Automotive and Embedded Networks
trouble when I distribute lvlibp using NI ADCS - VIs broken
I developped Packed Lib using NI ADCS toolkit (18.5). My customer wants to use it in his LabVIEW project but lvlibp Vis are broken if only the NI ADCS runtime is installed. (It works fine if activate the licence)  Any explanation?
LV2016
NI ADCS 18.5
NI XNET 18.5
Thank you
(2,918 Views)
Accepted by topic author JP_V
Hello
I found the solution, I have to load the lvlibp dynamically and it works. It’s not possible to add it directly in LabVIEW project (which is normal after All)
hope this help some one one day 😀
(2,865 Views)
