Automotive and Embedded Networks
synchronize PCMCIA-CAN/2 and USB-DAQPAD-6015
I would like to know if is it possible to synchronize data from a PCMCIA-CAN/2 and a USB-DAQPAD-6015 like using two PCMCIA cards with RTSI bus.
Tx for your answers.
(3,807 Views)
Hi christophe14,
it's no problem to synchronize a Series 2 PCMCIA-CAN/2 card and a USB-DAQPAD-6015. However, you might want to take a look at this this KnowledgeBase article.
Similar to using a PCMCIA-CAN and a DAQcard, you would need to use the PCMCIA-CAN Synchronization Cable to connect the PCMCIA-CAN card to the 68-pin connector of the USB-DAQPAD.
-B2k
(3,787 Views)
Thanks you very much biker2000.
See you.
(3,783 Views)
