Automotive and Embedded Networks
nccofig
 how to configure following attribute?
 AttrIdList[4]=NC_ATTR_CAN_COMP_STD;
 AttrIdList[5]=NC_ATTR_CAN_MASK_STD;
 AttrIdList[6]=NC_ATTR_COMP_XTD;
 AttrIdList[7]=NC_ATTR_CAN_MASK_XTD;
solution 1: Network Interface Object for transmit via CAN Objects; CAN0   Network Interface Object for Receive via CAN Objects; CAN1
solution 2:Network Interface Object for transmit via CAN Objects; CAN0    Receive via CAN Objects;
solution 3: transmit via CAN Objects;  Network Interface Object for Receive via CAN Objects; CAN1
solution 4:transmit via CAN Objects;  Receive via CAN Objects
sorry , I don't know mean in manual
(4,384 Views)
these attributes are only useable with Series 1 NI CAN boards.You can use them to configure a filter mechanism to receive specific frames only. If you use a Series 2 board use the filter properties instead.The filter works with network interface and objects.
DirkW
(4,365 Views)
