Automotive and Embedded Networks
how to clear data string on cRead multi
Hi i was wondering if anyone knows how to clear the data from ncRead multi? I'm using PCI-CAN Frame API and when I use the ncRead multi VI it reads thru all of my received data frames and I'm getting overlapping data until it is cleared from my indicator. Attahced is my VI:
(4,287 Views)
See the "Receive" example which ships with NI-CAN 2.4 or later. It uses a different but better way to print the Frame strings to UI.
DirkW
(4,278 Views)
