Automotive and Embedded Networks
error nican.dll
hello,
my computer doesn't load my application correct.
it seems that the vi's can't find the nican.dll because the message is "error loading nican.dll".
has anyone an idea?
markus
(9,809 Views)
what kind of application are you talking about? (VI with LabVIEW, EXE, c file with C++?)
Did you install NI CAN in order to have the DLL installed?
DirkW
(9,803 Views)
i've copied the nican.dll's to the windows\system folder and started my vi.
at start up an error message was shown.
i've got no other files installed.
markus
(9,801 Views)
In order to work with NI CAN hardware or software you have to install the complete driver . Its unfortunately not enough to copy some dlls.
DirkW
(9,791 Views)
Not totally sure, but I was recently having a similiar error and it was one of two things, if i recollect correctly:
1. The bus speed in my VI application and that set in the MAX were not the same.
2. The hardware was not present on the machine I was trying to develop on.  See this thread for being able to do it with Version 2.3 of the software drivers:
http://forums.ni.com/ni/board/message?board.id=30&message.id=605
per a post in there:
NI-CAN 2.3 introduced the ‘virtual CAN interface’ (aliases CAN256 and CAN257). Thus, if you use NI-CAN 2.3 (or higher) you can just initialize one of those aliases and use the generated TaskRef as an input for the nctGetProperty function.
Download the latest NI-CAN version here.
(9,732 Views)
