Automotive and Embedded Networks
XNET Memory Design and Management
Hi All,
I'm brand new to NI-XNET, using LabVIEW 2018 and an NI CAN peripheral.  I think my application requires the Frame Input Stream Mode because I need to analyze all frame traffic on the network, which does not conform to standard frame/signal definitions that I could put in a database.
The XNET Read (Raw Frame) VI returns all frames in the Raw Frame format.  I think the application must poll XNET Read (Raw Frame).
How are frames buffered, and what properties can I use to monitor or configure the buffer?  For example, are frames buffered in HW, in the driver's space, in application space, in all?  Can I see or configure the size of these buffers?  What will happen if the buffer overflows?  I'm trying to design the polling period, which I think is a function of the frame rate and the buffer size.
I appreciate any feedback or help,
Steve K
(3,204 Views)
Hi Pie,
I saw you made another post with this same question here that got resolved: https://forums.ni.com/t5/Automotive-and-Embedded-Networks/XNET-Memory-Design-and-Management/m-p/3897... .
I just wanted to include that link here for anyone else who stumbles across this looking for an answer.
C. Weeks
Product Support Engineer
NI
(3,180 Views)
