Automotive and Embedded Networks
XCP Master on LIN bus
Does NI ECU Measurement and Calibration Toolkit support XCP on LIN bus?  The datasheet shows only CAN and Ethernet, but hopefully this is wrong. If not, is there a plan to support the LIN physical layer?
(8,739 Views)
Hello dualtronic,
The datasheet is correct...we do not support XCP on LIN yet.
We are considering many things for future versions of the toolkit and XCP on LIN is something we are considering, but I don't know if or when it will be available.  I'm sorry about that.
O. Proulx
www.ni.com/support
(8,705 Views)
Any update on this?  Is there a solution for XCP on LIN yet?
(7,774 Views)
Currently looking into this - I'll let you know
David H.
(7,754 Views)
Just received an answer on this - We do not support XCP for LIN in the ECU Toolkit
Thanks!
David H.
(7,664 Views)
So to my question.  Is there a solution for XCP on LIN yet?  The answer is no, correct?
(7,658 Views)
Correct - The answer is no
David H.
(7,651 Views)
