Automotive and Embedded Networks
Where are my CAN icons? Installed LV7.1 and they disappeared.
I have since re-installed CAN (v2.2) with LV7.1 support, and the icons are still not there.
Any clues? Both the menus and vi.lib subdirectories have NICAN sub-folders.
Mike Evans
Mike Evans
TRW Conekt
N.I. Alliance Member, UK
http://www.Conekt.net
(4,074 Views)
Hi Mike,
did your LabVIEW 'Palette View' settings get changed (Tools » Options » Controls/Function Palettes » Palette View)? The NI-CAN palettes should show up in 'Advanced' or 'Express'.
Do you still have *.mnu files in this folder ...\LabVIEW 7.1\menus\default\can\ ?
-B2k
(4,068 Views)
With the newest version on NI-CAN, my CAN Pallette shows up under the NI Measurements Pallette (that is the palette that has motion, vision, DAQ, DAQmx,and whatever else you have installed), right next to the DAQ and DAQmx Pallettes. It does NOT show up on the root palette.
(4,063 Views)
Thanks DHuff - spot on.
Having only just installed v7.1, I'm obviously still finding my way around!
Mike
Mike Evans
TRW Conekt
(4,057 Views)
