Automotive and Embedded Networks
Question - using capl programming in canoe
I'm trying to use the capl language in canoe. I created a capl-node and included this node into the Can_network (as you can see in the jpg: simulation - canoe.jpeg
I created a capl-program to write a message into the canoe-write-window(message:The message received is x) if canoe receives any message.
Here you can see the program code in the CAPL-Browser:
on message *
    write("The message received is %c", this.id);
The CAPL-Browser compiled that without any warning or problems.
So now the problem: When I'm starting the canoe measurement occurs a error message in the write-window. Test module : the test module is not assigned or invalid. (as you can see in the jpg: measurement start.jpeg
I don't know what the problem is.. has someone an idea? Maybe something is wrong with the measurementsetup...
Padderick
Message 1 of 16
(48,058 Views)
ups, here the jpg's...  😉
Message 2 of 16
(48,057 Views)
I took what you had and placed it in a CAPL node I have and it works fine.   Make sure you have configured (right click on the node in the simulation view and select "configure") the node for the database you are using and state (simulated or off).  Additionally be sure that you have saved the compiled code with a .can extension and Title reflects the name you have given the file while the path on the common tab points to it.  Additionally, in configuration on the buses tab the CAN bus should appear in the right hand window under "assigned buses".
Let me know if this helps.
GCentral
Message 3 of 16
(48,041 Views)
Could you please tell me how to generate a test report in notepad using CAPL ??
Best regards!
Message 4 of 16
(45,156 Views)
Hello, I now got the same message that "The test module is not assigned or invalide" Have you got the solution? I wonder if you could please advise.
Thank you in advance.
Message 5 of 16
(44,416 Views)
Could you share a screenshot of the node configuration?
BR
Message 6 of 16
(42,979 Views)
To write a report, you must do the next:
dword glbHandle = 0;
char buffer[64];
glbHandle = OpenFileWrite ("report.txt",2);
if ( glbHandle!=0 )
    snprintf (buffer, elcount(buffer)," %d \n", aux);
    filePutString (buffer, elcount(buffer),glbHandle);
else
      write ("File 'report.txt' was not opened for write access.");
I hope you will find this informaiton useful,
BR.
Message 7 of 16
(42,975 Views)
Yes i already managed to generate reports 🙂 Thanks anyways !
Message 8 of 16
(42,972 Views)
Hey,
Problem with Simulation Setup..
Message 9 of 16
(42,971 Views)
how can I use CAPL programming anc panel designer in CANoe version 8.5
Message 10 of 16
(38,820 Views)
