Automotive and Embedded Networks
Pdo Problem
Hi all ,
I am testing the PDO's ...I have attached the code and error windows.Please tell me were i am wrong and why i get this type of errors,The Error with PDO occurs at"CANOPEN PDOCrate.vi" and other at File open .I am new to this Labview field.
(4,680 Views)
Hello.
Thank you for posting to the NI Discussion Forums.
The error 8 that you are seeing usually indicates one of two things are happening.  There is a great knowledge base article on this error at:
Why do I get "Error 8 Occurred at Open File" When Writing to or Reading From a File?
http://digital.ni.com/public.nsf/allkb/F5D5F6798A9367CC86256F6C007A968D?OpenDocument
In terms of the error 1 that you are seeing, this indicates that one of the inputs to the CANopen PDO Create.vi is invalid.  I think that the PDO Configuration terminal on this VI requires a cluster of information, but you only have a constant integer.  Try changing this constant to a control and filling in the appropriate fields on your front panel to correct this error.
Let me know if this helps!
Brian F
(4,642 Views)
