Automotive and Embedded Networks
PDO Receive ASCII Channel
Hi all,
I'm new to CANOPEN and would like to ask some questions regarding PDO mapping and ASCII channel.
I have a Servostar S600 amplifier and a PCI-NICAN series 2 card.
I have the information as followed :
- ASCII channel is default-PDO
- Up to 8 characters can be sent in 1 PDO (must be terminated by CR LF)
- More than 8 characters must be segmented.
- RPDO2 COB-ID is 301H
- This required NMT status machine in the operational status.
- SubIndex 00H, Value 1H (number of entries)
- SubIndex 01...08H, Value 31000208H (ASCII chars 1 to 😎
- Example diagram like(send ascii GVFBT)
                              COBID  Byte0     Byte1  Byte2  Byte3  Byte4  Byte5  Byte6  Byte7
MASTER -> S600     301H     47H     56H     46H     42H     54H     0DH     0AH      0H
                                            [G]       [V]       [F]      [B]       [T]       [CR]    [LF]     NULL
My questions are :
- Do I have to do pdo mapping since it is already default as RPDO2? (Mapping means select empty PDO, delete data, insert data, then configure it to SYNC)
- How do I "call out pdo"? Is it like "calling SDO"? where I should have the COBID, control byte, index, sub index and data?
- I don't understand what is the meaning of
- How do I implement more than 8 chars, simply define the data length to be more than 8?
Appreciate if one can advice me in any manner. Thanks!
Steve
Message 1 of 1
(6,948 Views)
