Automotive and Embedded Networks
Need help setting up AUTOSAR E2E protocol CRC channels with NI-VCOM
Our CRC is Autosar E2E P02, In RBS Descriptor which configure method to select?
Message 11 of 23
(4,578 Views)
Do you have arxml file? Or you only have the dbc file?
End-to-End Communication Protection
https://tmesystems.net/
Message 12 of 23
(4,568 Views)
Yes I have using an ARXML file. Signal transmission and receive we using Xnet(Frames & Signal Single point).In this case how to use RBS config file and arxml file parallel.How to synchronize rbs and signal drivers.
Message 13 of 23
(4,514 Views)
If you have the ARXML file, you don't need to use the RBSDescriptor File. The RBSDescriptor file is only for DBC or LDF database file.
Just go ahead and create a RBSConfig. Specify the ARXML and NI-XNET in WebUI (Using NI-VCOM WebUI to Create the RBSConfig File). Then explore and run the shipping example using the RBSConfig file.
Message 14 of 23
(4,502 Views)
Thank you FYI,
 How to Configure E2E,CRC and SOK in Web UI.
Message 15 of 23
(4,453 Views)
@donbosco100 wrote:
Thank you FYI,
If they are defined in the ARXML, you don't have to configure them. NI-VCOM will load the configuration from the ARXML file.
Message 16 of 23
(4,447 Views)
In the arxml file how to confirm the CRC E2E configured.
Message 17 of 23
(4,425 Views)
I am not familiar with arxml database file, but based on the information in E2E Protocol Specification, you should be able to search the keyword E2E with a notepad.
Message 18 of 23
(4,418 Views)
Hi ZYOng Please help for ARXML file configuration in Web tool.I have tried there is no clear output. Please if you have any knowledge share we are struggling this part many weeks.
Message 19 of 23
(4,315 Views)
I can't help you without access to your ARXML file, which I believe is proprietary.
You should reach out to NI Support for better guidance.
Message 20 of 23
(4,303 Views)
