Automotive and Embedded Networks
NI-XNET nxBlink() what session type to use ?
What session to pass to nxBlink() NI-XNET function ?
I tried to pass sessions obtained from:
- nxCreteSession(..., nxMode_FrameInStream, ...)
- nxCreteSession(..., nxMode_FrameOutStream, ...)
But I get error. The nxBlink() help only says use "The XNET Interface I/O name".
but that doesn' tell me what kind of session out of these to use:
nxMode_SignalInSinglePoint 0
nxMode_SignalInWaveform 1
nxMode_SignalInXY 2
nxMode_SignalOutSinglePoint 3
nxMode_SignalOutWaveform 4
nxMode_SignalOutXY 5
nxMode_FrameInStream 6
nxMode_FrameInQueued 7
nxMode_FrameInSinglePoint 8
nxMode_FrameOutStream 9
nxMode_FrameOutQueued 10
nxMode_FrameOutSinglePoint 11
nxMode_SignalConversionSinglePoint 12
(6,774 Views)
It's not expecting a session name but the physical port name, like CAN1 or LIN2. Just wire a constant to the terminal and choose the right port if you have a XNET device connected to your computer (it will be in the list). If you're using a remote system, you must know the name of the port (MAX helps for this).
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
(6,743 Views)
I already found out that system type of session leads to interface/port type of session that can be used
to blink the particular port LED.
Thank you, Radek
 // Open system session.
        nxCheckErr(nxSystemOpen(&l_SystemRef));
 // Each Interface is represented by a u32 (4 bytes).
         l_NumberOfInterfaces = l_PropertySize /4;
         l_pInterfaceNames = (char**)malloc(sizeof(char*)*l_PropertySize);
         l_InterfaceBuffer = (u32 **)malloc(l_PropertySize);
         // This property returns the u32 value for each interface.
         // You can use this value to get individual interface properties
         nxCheckErr(nxGetProperty (l_SystemRef, nxPropSys_IntfRefs, l_PropertySize, l_InterfaceBuffer));
         // Get the individual interface names.
         for (i = 0; i < l_NumberOfInterfaces; i++)
            nxCheckErr(nxGetPropertySize((nxSessionRef_t)(l_InterfaceBuffer[i]), nxPropIntf_Name, &l_PropertySize));
            l_pInterfaceNames[i] = (char*) malloc(l_PropertySize);
            nxCheckErr(nxGetProperty((nxSessionRef_t)l_InterfaceBuffer[i], nxPropIntf_Name, l_PropertySize, l_pInterfaceNames[i]));
            // Identify the port that match the resourceDescriptor.
            if (0 == strcmp(resourceDescriptor, l_pInterfaceNames[i]))
                actualInterface = (nxSessionRef_t)l_InterfaceBuffer[i];
                nxBlink(actualInterface, 1); // Blink particular port for identification and
                Delay(1);                    // indicate that input stream was succesfully opened.
                nxBlink(actualInterface, 0);
(6,739 Views)
