Automotive and Embedded Networks
NI XNET CAN, NI PXI 8513/2, KWP2000
Hello All,
I am using NI-PXIe-1071 with NI-PXIe-8821 as my chassis and one CAN module NI-PXI 8513 which is a 2 port CAN module. Now am trying to communicate with ECU through CAN module using KWP2000 protocol. In NI MAX, there is no problem i can able to communicate but through my labview code I could not, an error has been generated. I have attached the error code kindly tell me suggestions.
Thanks in advance.
(3,829 Views)
Could you tell me what values you entered into the vi?  Also, it would be better to attach the vi itself rather than a picture of it.  I will also report your post to a moderator to move to the Automotive and Embedded Networks forum, which is more appropriate for XNET and ADCS questions.
I did find a result when googling the error code itself (using Help->Explain Errors yields no results) - http://download.ni.com/pub/gdc/tut/nican_errors_en.pdf mentions it as an NI-CAN error:
"You used a baud rate that is not valid for your transceiver type. For example, Low-Speed transceivers are limited to 125 k, and Single-Wire transceivers are limited to 100 k. Solutions: Use MAX to specify a valid baud rate in the interface Properties dialog; for the Frame API, specify a valid baud rate in the Config function for the Net Interface."
Note that there is a special syntax that you have to use if you want to use NI-XNET instead of (the obsolete) NI-CAN for the ADCS.  If you look at the detailed help for the Open Diagnostic Session, it should be able to give you more details.
(3,712 Views)
