Automotive and Embedded Networks
NI-XNET C API for CAN Loopback Test - No Baud Rates Above 125k Work
Using the NI-XNET C API Loopback Test Example, baud values of 125k or less work as expected receiving exactly what was transmitted. Whenever I change the baud rate in the CAN database to any value above 125k baud, the loopback no longer works (received payload is all 0's).
Driver used: NI_XNET 20.0
Hardware used: USB-8502
Using this Example Visual Studio Project:
C:\Users\Public\Documents\National Instruments\NI-XNET\Examples\MS Visual C\CAN\CAN_Loopback_Test
Using this Example CAN Database:
C:\Users\Public\Documents\National Instruments\NI-XNET\Examples\NIXNET_example.xml
I tried setting the following properties as well to no avail: nxPropClst_BaudRate64  nxPropSession_IntfBaudRate64
Message 1 of 12
(4,439 Views)
Accepted by topic author whoisjohngalt
you need to add termination to your CAN bus, either with external termination resistors or by setting the XNET Termination property to enabled on your two sessions before writing anything.
Message 2 of 12
(4,438 Views)
Thanks that solved it! Should have read the comment at the top of the file.
// Please make sure that the bus is properly terminated as this example does not
// enable the on-board termination. Also ensure that the transceivers are
// externally powered when using C Series modules.
Message 3 of 12
(4,426 Views)
Hi.
I have the 120Ohms resistor externally but, I still having the timeout. My usb8502 is one port only, should be this the issue? What is wrong? Thanks
Message 4 of 12
(2,776 Views)
You should make your own post. If you are new to CAN you should checkout my CAN Blog.
https://hooovahh.blogspot.com/2017/03/can-blog-introduction-and-downloads.html
Message 5 of 12
(2,771 Views)
Does it work for you at lower speeds?
Message 6 of 12
(2,767 Views)
Yes. I am new in CAN. That i why I am looking for answers to help me to understand. Thanks for the blog link I will read it all.Thanks
Message 7 of 12
(2,758 Views)
This is what I got from LabVIEW and the CAN 120ohm termination. is it ok?
Message 8 of 12
(2,750 Views)
The example you showed will write on one port, then read it back on a second port that is wired together.  You only have one port, so I'm not sure what you were expecting to happen.  It timed out because it couldn't read anything.
Message 9 of 12
(2,744 Views)
Hello.
Yes Hooovahh. At the beginning I was thinking about the second port but, I was expecting to see some response once I plugged the 120Ohm. As you may know I am a beginner and i am trying by practically to understand what is happening with this example. But It seems that it does not work. So, until I have a second port I will see the final response.
Message 10 of 12
(2,740 Views)
