Automotive and Embedded Networks
NI USB 845x SPI communication with Max1108
I'm trying to communicate with the Max1108 (datasheet attached)
when using 8451 Test Panel I get random results,only once i got expected results and i captured this moment(i cant reproduce it somehow)
 I followed this code,
http://forums.ni.com/ni/attachments/ni/170/283809/1/MLX90316%20Read.c
which was published by NI in forums..and got same results when I use script functions(code1), and empty read buffer when using regular spi API's (code2)
Please  ignore the c# adjustments ..
what am i doing wrong ?
Ori
(5,978 Views)
Solved, thanks for your "help"
(5,838 Views)
