Automotive and Embedded Networks
LIN: Error Power Missing on Turn On PXI
I have a problem with my LIN communication.
Randomly I get "Power Missing"-Error on my LIN Card, which I use in a PXI, on startup of the system.
The thing is that there is always voltage on the right Ports, but sometimes this error occurs.
If we do a short disconnect/connect it works fine again and the error is gone.
This doesnt happen everytime so we dont get the point what is wrong.
Someone here with an idea?
br
Sagi
(6,646 Views)
Hello Sagi,
is the application deployed as an exe file or is it run inside LabVIEW?
If it is an exe file which is run at windows startup (autostart entry) then I would say
the drivers are not yet ready when the application tries to access the device.
Peter
(6,614 Views)
Hi Peter,
thanks for your answer.
It's deployed as an .rtexe which is running on a PXI system at startup.
May there is the same problem?
For me, it does not sound like it could be that problem. Because if you start the PXI it first loads all the drivers and after this it would load the startup.rtexe
br
Sagi
(6,609 Views)
Hi Sagi,
no, that is not necessarily true.
One option is to add a wait time of 10-30 seconds to your rtexe before trying to access any network variable or a ressource.
The better option would be a proper error handling where you check the device communication
for errors and retry opening the connection if an error occurs.
Best Regards,
Peter
(6,590 Views)
