Automotive and Embedded Networks
LIN 0x2011 framing error using USB-8476 + Vector CANcaseXL
I'm using the USB-8476 on a LIN bus to talk back and forth with my DUT. As I develop in LabVIEW, I've been using CANalyzer to monitor the bus as I test new messages. Everything was swell until I started implementing a full frame message, as opposed to a header frames. With CANalyzer running, I consistently get a 0x2011 framing error after every full frame I send. As soon as I stop the measurement in CANalyzer, I stop receiving errors and my DUT responds correctly to my full frames.
I have the CANalyzer measurement configured with master mode OFF and the master resistor OFF, which is why I thought I was in the clear. Having written this up, this is probably more of a CANalyzer question than anything, but can anyone offer some guidance?
Cross-posted to LAVA forums.
(6,736 Views)
Hello asbo,
Thanks for the post, unfortunately NI does not support Vector's CANalyzer. You may find more information by contacting Vector or on the LAVA forums you have already posted on. Good luck with your application!
Paul-B
(6,707 Views)
