Automotive and Embedded Networks
How to speed up the NI 9853 CAN data acquiring with ID filters
I am using NI 9853 on a cRio 9111 to collecting CAN data. I am only interested in three IDs from the CAN database.
I need collect the CAN data in a 10 hz base.
I am using FPGA and Labview real time.
The problem I have is that somehow the CAN seems receiving the three ID frame randomly. I can't get all three frame within the 10 hz period.
(I can get all ID data in every 2-3 seconds.)
Attached is the testing project(LV 2009, FPGA and Real time). Is there any way to make CAN fast or to optimize the code to make it work?
Thanks!
(6,930 Views)
Hello LUX_,
It is possible that these frames are only going on the bus every few seconds...which means you will only be reading them every few seconds.  Are you sure that all 3 frames are going on the bus within100ms?  You could use the shipping example that logs all frames to a file to find out exactly.
O. Proulx
www.ni.com/support
(6,849 Views)
Thanks O. Proulx.
Somehow after I re-write the same FPAG code on a new vi, it is magically working now.
The CAN loop is 100 or even 1000 times faster than before. I was able to get all three frame within the 10Hz period.
Thanks for your reply.
Lux_
(6,820 Views)
