Automotive and Embedded Networks
How to detect device connected to Ethernet
How do I detect devices connected to Ethernet using LabVIEW.
My requirement is:
I need to detect all devices connected to ethernet in my network.Need to list down all IP of the devices.
Can anyone help me in this...
(7,197 Views)
Yup, I created a IP scanner once in LV. its was not the fastest...but.. it worked and did its job - can probably think of better methods now. think I used standard command prompt commands and parsed the reply, got also the MAC adress of the connected devices I believe. Can post the block diagram code tomorrow if I find it in my library (was a long time ago) and you still need it.
(6,961 Views)
Found it. However its written a long time ago when I still created spagetti diagrams that give you eye diarrhea, and its bad coding. If someone should use it and cleans it up, please post the cleaned up version 🙂
It uses the arp command. prob. other ways to solve this too
(6,951 Views)
