Automotive and Embedded Networks
How can we download the CANOPEN version for LabVIEW 8.5?
We already bought a CANOpen library that's support the LabVIEW 8.2. How can I get the update for 8.5? Do I need to reorder it? The actual version it is not able to be installed anymore on actual LabVIEW version. What will happend for the 8.6? I didn't see any support for this version yet. This cannot be changed to do not be a LabVIEW version indipendent?
Thank you,
Teodor
(6,728 Views)
Hello Teodor,
Although the CANOpen library is not officially supported in LabVIEW 8.6, you should be able to use it by copying the following files/folders to the corresponding 8.6 directory:
<LabVIEW 8.2>\examples\CANopen,
<LabVIEW 8.2>\help\lvcanopenvhelp.chm,
<LabVIEW 8.2>\help\lvcanopenvhelp.txt,
<LabVIEW 8.2>\user.lib\CANopen.
 <LabVIEW 8.2> corresponds to the location of your LabVIEW 8.2 folder usually C:\Program Files\National Instruments\LabVIEW 8.2.
Please let me know if this helps.  Have a great day.
O. Proulx
www.ni.com/support
(6,712 Views)
I will try it. But there is only one thing. Once that you update the LabVIEW version those files will be deleted. Do you know a way of unpacking of the CANOpen Library kit then. Anyway I will keep this solution for the future too.
Teodor
(6,702 Views)
