Automotive and Embedded Networks
HELP: Compiling a file that includes nixnet.h with C99 extensions doesn't work
I'm kind of surprised by this.  If I compile ANY of the xnet examples that include nixnet.h with "Build with C99 extensions" enabled, nixnet.h will not compile with the following error:
"Types based on variable length arrays are illegal in structs or unions".
Why is this?  How is it that the new XNET API isn't able to compile with C99 extensions?
Given that I've used some C99 extensions in other parts of my code, I'm now stuck.  If I have to back out those changes, it requires more time to rewrite code that is otherwise working fine.
Message Edited by KavehV on 04-08-2010 04:20 PM
(7,321 Views)
Does the warning indicate a line number?
What compiler are you using?
I just tried to compile in a gcc version with -std=c99 and I did not get this error.
(7,304 Views)
I am guessing that you are using CVI... for a workaround, you can edit the nixnet.h file and replace lines 1889-1901 which are:
typedef nxFrameFixed_t(8) nxFrameCAN_t;
typedef nxFrameFixed_t(8) nxFrameLIN_t;
typedef nxFrameFixed_t(1) nxFrameVar_t;
with
typedef struct nxFrameCAN_t
   nxTimestamp_t Timestamp;
   u32           Identifier;
   u8            Type;
   u8            Flags;
   u8            Info;
   u8            PayloadLength;
   u8            Payload[8];
} nxFrameCAN_t;
typedef struct nxFrameLIN_t
   u32           Identifier;
   u8            Type;
   u8            Flags;
   u8            Info;
   u8            PayloadLength;
   u8            Payload[8];
nxFrameLIN_t;
typedef struct nxFrameVar_t
   u32           Identifier;
   u8            Type;
   u8            Flags;
   u8            Info;
   u8            PayloadLength;
   u8            Payload[8];
} nxFrameVar_t;
Message Edited by GPIB Guru on 04-09-2010 09:26 AM
(7,293 Views)
If you are using NI-XNET 1.0 (my prior information was for 1.1), then the lines are 1614 and 1615 and you would replace them with
   u32           Identifier;
   u8            Type;
   u8            Flags;
   u8            Info;
   u8            PayloadLength;
   u8            Payload[8];
} nxFrameCAN_t;
   u32           Identifier;
   u8            Type;
   u8            Flags;
   u8            Info;
   u8            PayloadLength;
   u8            Payload[8];
} nxFrameVar_t;
Message Edited by GPIB Guru on 04-09-2010 09:25 AM
(7,290 Views)
I'm using CVI 2009.  I found that this is apparently a bug with CVI 2009 compiler.  I haven't been told when a fix is expected though.
Message Edited by KavehV on 04-09-2010 11:28 AM
(7,274 Views)
Yes - but if you make my changes, they should get you working.
(7,266 Views)
