ni.com checkout is currently experiencing issues.
Support teams are actively working on the resolution.
02-09-2011 02:23 AM
Maybe I should add, that you may close the particular database objects, but not the entire database. This indeed would revert the settings you did before starting the session.
02-09-2011 08:39 AM
What I found is if I modify the frame properties, create sessions, and then close all database objects as well as the database before I start the sessions it doesn't seem to give me the errors I have been recieving, and the frames seems to still stick with the changes. I also tried to close all objects except the database itself until after I stop and clear the sessions. The I close the database. Then I still get this error which I will attach.
02-09-2011 11:42 AM
can you post the NI-SPY log file, maybe this helps us to see where your problem is coming from
02-10-2011 04:02 AM
NI-SPY log is a good suggestion. Stop the execution immediatly when the error occurs (on the error output of the Database property node use Custom Probe / Conditional Error Probe and in the Condition tab set the checkbox on Error). Also set a probe on the IO name input of the XNET Database property node (or Open Database database output).
When the VI stops on error, save the NI-SPY logfile and post it together with the database IO name.
