Automotive and Embedded Networks
Filter NI Embedded CAN
is it possible read with sbRio embedded CAN(CANRead.vi) on the same port by two differente loops?
For each loop i would set a different ID filter.
Manuel
(5,460 Views)
No. When you perform a read the read will retirn all messages in the hardware buffer since the last read. Imstead set up a producer consumer loop where one loop reads and based on the ID sends the message to another loop.
(5,454 Views)
