Automotive and Embedded Networks
Error writing and reading CanBus data in the HDF5 File Format
Having issues writing raw can bus data frames to disk using the hdf5 file format. A can frame is cluster with several different data types.  The payload can be variable length. In my test vi, i can successfully write and read an array of empty can frame but when I fill the payload array with numbers it fails with Error 402760. Any idea what I am doing wrong?
Sorry first posted to general forum but was not getting no traction and decided to post here.
No Error
Writing and reading an array of raw can frames
Data - ErrorData - Error
Error occurs when I add data to the payload
Message 1 of 1
(1,470 Views)
