Automotive and Embedded Networks
ECU Measurement and Calibration Toolkit 2.3.1 problem with large A2L file
Hi to all,
I repost this question here as Hooovahh suggested to me.
I'm using ECU MC (2.3.1) with a quite large A2L file (about 900 Measurements plus some Calibrations) but apparently with such large database the "Text to Double" and "Double to Text" conversion VIs stop working properly. In particular the Double to Text Conversion VI that should work with "Enumeration Text" and "Range Text" "Scaling type" output only empty strings (without any error).
I suspect that this problem is related with the size of the database because I've created by hand a reduced version of my A2L database (with only 4 Measurements) and the conversion works properly.
Has anyone ever used ECU MC with such large A2L files wihout issues? (large means "real", i'm working with an ESP ECU and 900 measurements are normal)
I'm really disappointed with this toolkit that seems to be a (not cheap) collection of buggy .dll
Thanks for any reply
D.
ps: sorry in advance but I can not share the A2L file I'm working on
(5,740 Views)
can you please open a Service Request thread at your local NI support so that we can discuss this issue further and work together on a solution.
(5,734 Views)
I would suggest opening a Service Request (preferred) or emailing the can PSE at canpse@ni.com about this issue. It soulnds like a problem they should try to reproduce and take a closer look at.
Jeff L
(5,697 Views)
