Automotive and Embedded Networks
Difference between ncConfigCANNet.vi and ncConfigCANObj.vi
What is the difference between ncConfigCANNet.vi and ncConfigCANObj.vi? What is a CAN Network Interface Object and a CAN Object? Can you give examples.
Peter
(5,149 Views)
Basically, the ncConfigCANNet.vi is for configuring the ENTIRE CAN bus, (speed, frame length, filters and masks, etc). The ncConfigCANObj.vi is really for 1 CAN object on the CAN bus. (CAN Message, repitition rate, etc)
So you configure the whole bus using ncConfigCANnet.vi, then configure each of your objects using a ncConfigCANobj.vi
Hope this helps,
(5,137 Views)
Peter
(5,117 Views)
    I am getting -1074388736 error code with ncConfigCANObj.vi for message ID 1155 i.e 0x483. But for ID1156 there is no error.
After this message I get the error code for all the other message(decreasing order)in the dbc file. Can somebody please help me.
It is very urgent.
The CAN Object Config Values are
Period                                                  100
Read Queue length                              0
Write Queue Length                             0
Receive Changes Only                       FALSE
Communication Type                         Transmit Data By Call
Transmit By Response                       FALSE
Data Length                                         8
Siva
(4,114 Views)
