Automotive and Embedded Networks
Devicenet explicit messaging- Attribute?
I am trying to set up an explicit message to communicate with an SEW EUROdrive.  Attached is the explicit message format for the drive-  I do not see how to mesh the labview explicit messge VI with the required formant.  There is no where in the explicit message VI to specify the attribute-  How does the explicit message VI format the message frame?
Please any help is appreciated.
Nathan
(7,440 Views)
The attribute within a explicit Message read request is normally specified within the DATA. So i guess attribute 4 is represented by h2070. What happens if you execute the example without specifying the attribute ID?
DirkW
(7,409 Views)
Is it a MOVITRAC http://www.clrwtr.com/SEW-Eurodrive-MOVITRAC-Inverters.htm or MOVIDRIVE http://www.clrwtr.com/SEW-Eurodrive-MoviDrive-Motor-Controllers.htm ?
(6,753 Views)
