Automotive and Embedded Networks
Can i change or manipulate the sync byte in a LIN network?
I am using USB 8476 to communicate as the master in a lin network. The slave is a light control panel used in trucks. I want to do a test on the lin network and have to see what would happen if i were to change the sync byte ? So my question is it possible to change the sync byte ? Can i change the checksum also ?
Thank you.
Message 1 of 1
(6,711 Views)
