Automotive and Embedded Networks
Can bus reading
I'm new to CAN interfase so I need some help to create an application to read temperature from CAN bus using usb-8473. I tried several VIs created using Frame API pallete,  but I only get data in hexadecimal format. is there any ready VI wich converts CAN singnal data and creates measurement file? if anybody has some simple programs, will be very helpful.
(6,108 Views)
USB 8437 is able to deal with frame API only
If you want to convert frames to signals i suggest to use NiXNET Conversion sessions in addition
(6,099 Views)
